MY CAR-The Bolt on Car
Old 06-03-2006, 08:58 PM
Shon Herron's Avatar
Default MY CAR-The Bolt on Car
IF ANYONE wants the parts run down on the car I can provide. (or do a search for my screen name, it has all been listed)
Since some do not believe that it didn't have the stock clutch in it for all the record setting runs EXCEPT the 11.80 pass (remember, every pass it made before 3/25/06 it was record breaking), it had a stage 3 Spec DISC and stock PP/TOB/etc/plus lighter than previous runs and I can show you a pic that it was not even grabbing properly, just think if it had grabbed!?!?!?
And some are right, my car was not consistant with the M6, it actually got quicker as more passes we made. I guess that sort of sucks for those that cant run the M6. (BTW- I KNOW I cant run the M6, that is why Russ was the driver).
Watch this video, you tell me if you can tell if it is an M6 or Auto car: http://media.putfile.com/Herron-Performance
This is typical of all of Russ's driving.
This car is an open book, you ask and I will tell, I have nothing to hide, the car is what it is. And when you get ready to run better than the avg you can look me up, the combo is repeatable, Russ and I have several cars that we have worked with that run exceptional for what they have done to them. IF you want those examples we can provide those too. READ alot BUT dont believe all the magazines and internet BS. Decide on a goal and do what it takes to get there. BUT find out who is actually meeting the goals you have and talk to them. You can not go anywhere with out a destination and compromises will kill ya.....
Shon Herron is offline
Old 06-03-2006, 10:22 PM
License2Ill's Avatar
Oh I beleive you, most aftermarket stuff is all jazz, very few are true upgrades. I just picked up a clutch and PP and I went with a Valeo, end of story and when I get my 9 inch I may upgrade the clutch alone, to either Ram or Mcleod, why'd u go with spec?? seen some pictures man and the springs can fall out!!! to me that's just incredible, high prices plus big claims, and yet ppl who see big failures!!
Nice run, looks like your burning good, who tuned your PCM? plz don't say stock. I'd like to come close to those times NA with a ZZ4 cam someday, then install NOS. ANd be happy.
License2Ill is offline
Old 06-04-2006, 12:15 PM
I do my own tuning so it has the Herron Performance tune in it.
Spec b/c it was here.
And the pricing of Spec is respectable when comparing to those other brands.
Old 06-04-2006, 12:24 PM
JerseyLS1TA's Avatar
Nice car, what song is that?
JerseyLS1TA is offline
Old 06-04-2006, 12:33 PM
urbanhunter44's Avatar
I don't disbelieve your mods at all, I think you've got one sick car!
i watched the vid.. you dont by any chance have those runs on vid without the music?
urbanhunter44 is offline
Old 06-04-2006, 01:31 PM
edlt1's Avatar
whats your bolt on list?
thats a badass car.
Any weight reductions that you can suggest that I may have missed?
like stuff that you wouldn't think off.
Thanks
edlt1 is offline
Old 06-04-2006, 01:50 PM
Dragframe's Avatar
man that guy can drive...
Dragframe is offline
Old 06-04-2006, 03:13 PM
Resident Racing Jerk
vtec's Avatar
here's one with no music.
http://webpages.charter.net/bigjermes/Shonscar_0001.wmv
vtec is offline
Old 06-04-2006, 03:27 PM
CAI, stock TB bored to 52mm, Hooker LTs, Hooker Y-pipe, LT4 springs, Pro Mag SA 1.6RRs, EWP, !ABS/LL, Relocated Alt, !PS, !A/C, 12" fan, BMR K-member, BMR A-Arms, QA1 12ways/springs, Spohn Rod ended TA, Spohn Rear Drag bar, Warrior rims, 4" LW Hood, !interior, !radio, Moser 12bolt/4.33/spool, Taylor Wires, champion plugs, Herron Performance Rod ended LCAs/PHR, Herron Performance Tuning with OBDI Conversion from MadZ28, !bumber supports, B&M Ripper Shifter, LW Battery.
Stock clutch for all but the last 2 runs, as mentioned above those were made with the Spec Stage 3 disk.
I think that is all the mods, if I forgot any it was not on purpose.
RW on 3/25/06 was a hair less than 3100.
Old 06-04-2006, 04:57 PM
So your dyno'd and tailor tuned accordingly?? Do you feel this is a key component? I've got PCMforLess tuning cuz I just can't afford dyno time. But am fairly happy with it, altho I burn kind or rich.
I've considered investing on a wideband sensor, then doing a datalog and then sending the log to someone to burn a chip for me, but I've never heard of anyone willing to tune using a customers datalog, I figure using a wideband would yield the equivalent of a dyno, so long as some one is willing to tune a pcm file based on my data. You think setting something like this up would give good results?
Do you think a Ford 9 inch robs to much HP?? I hear it soaks up a lot of hp. But I personally prefer it becuz I never hear horror stories about it, also I'd like to eventually have 2 center sections to swap between.
Old 06-04-2006, 05:03 PM
1fast97gsx's Avatar
It seems a lot of your performance came from weight reduction. Let me get this straight ... this was done on STOCK heads and cam? Bolt ons only?
1fast97gsx is offline
Old 06-04-2006, 05:05 PM
All my tuning is from datamaster logs and MPH readings at the track. this car has never been near a dyno
Tuning of the PCM and suspension is key.
ALSO, watch the weather.
Old 06-04-2006, 05:08 PM
Weight is your ememy.
STOCK everything.
But for an example of another car that is running well with only minimum weight reduction is Jeff G's his 97 T/A with OBDI PCM and my tuning is running 8.0s/85, he has removed rear seats/jack/spare/rear bumper supports. 4.10s gears in 10bolt, Th350/3000 Vig Stall. Larger rear sway bar. No headers yet....much less any other good mods...
Old 06-04-2006, 05:14 PM
Wow that's awesome man, your doing it my way. Who's wideband you using? or are u going even thrifty-er than me....working the figures straight from our stock O2's?
Also when ppl dump the front and rear bumpers are you guys putting anything at all in there??? I mean nakedness is chic-ie but...what if!!?
Old 06-04-2006, 05:25 PM
Pull bumper supports and then cut whatever metal is not needed. I have not cut metal YET.
I have not purchased the WB yet but need to.....
Old 06-04-2006, 05:34 PM
LT14LIFE JT's Avatar
We all know you're the man on the bolt-on LT1, Shon..There's no doubt about it..I know you could come up here and beat the fastest SI LT1 by over 1/2 a second... Is someone trying to make you out to be a liar or in disbelief of your work? I'm confused as to why an aftermarket clutch wouldn't be considered a bolt-on.
LT14LIFE JT is offline
Old 06-04-2006, 06:10 PM
slowmofo's Avatar
FYI- Song is Cold By Crossfade
slowmofo is offline
Old 06-04-2006, 06:44 PM
Dragframe's Avatar
that is amazing... now with that t-braked auto see what you can turn...
I will have to say though... that is some of the BEST 60"s ive seen wiht a manual...
Old 06-04-2006, 07:37 PM
Clean94Z's Avatar
Shon is someone disputing what your car runs or has in it?
Clean94Z is offline
Old 06-04-2006, 07:45 PM
https://ls1tech.com/forums/lt1-lt4-modifications/517537-predictions.html
I sure hope Camaro22 (or whatever sees this thread)
Quick Reply: MY CAR-The Bolt on Car
