Whos running good times with stock heads?
I am building my forged 347 as we speak, but I dont have the $$$ for some good heads so I am going to run 243 castings till next year. What cams/setups you fast guys running? Car will have quite a bit of weight out, 4.10's and a TH-350 with 4500 stall.
Thanks
Thanks
Originally Posted by SMOKIN01TA
still over 150lbs heavier than the automatic guys, im doing some "construction" on the car at the moment to see where they gott all of that weight from tho
Thanks!
Originally Posted by a98ws6
Could you go into more depth on your setup, suspension, gearing, race weight?
Thanks!
Thanks!
3000lbs raceweight, hall shocks and drag springs, 4.56 gear, stg.4 clutch, 28w tire and ALOT of tunning of the suspension
the older ones left alot on the table anyway in comparison to the newer heads
I went 11.7's @ 117 when I had the stock motor with the shitty casting stock heads from '99. That was at about 3500 lb raceweight, and on a 100 wet shot it went 10.49 @ 129 with that same setup and it was just a little 228 comp cam.
11.5's here. Very mild mannered 230/236 cam, pretty much fullweight. Drive to the track with slicks in the car, swap em at the track, and drive home.
I could say 11.30/40 if my dang 60' would be lower.
