Which launches harder..camaro w/ 9 inch w/ slicks, or awd EVO
I have a buddy with a 350 whp EVO who is thinking that he is going to win at the track. This has been a **** talking contest for the past few months, and has started to aggravate me. Heres the issue. I broke my 10 bolt last week and am buying a new moser rear end unit tommorrow. Im undecided whether to go with a 9 inch w/ 4.11's or a 12 bolt with 4.11's. Anyway, weve decided that street racing probably wouldnt be the smartest way to do it, so were going to the 1/4 track at Bandimere, which is about 5,500 feet above sea level. So heres my question, will a procharged f body making 380 - 400 corrected WHP beat an EVO with 350 corrected WHP, provided i have weld prostars out back with 26x10x15 mickey thompson et drags and skinnies up front. I will also be getting a new clutch before the race, probably a spec stage 3+. He seems to think he will beat me out of the whole even with the slicks, but i'm pretty sure he cant outlaunch a RWD car with a 9 inch/12bolt and 4.11's with a strong clutch. What do you guys think? My car is a 93 z28 6 speed. Mods in sig.
Lol I just pulled a bad holeshot on a bottom 13 second Evo last week at the track, running MT drag radials. I had a 1.71 60', he was in the high 1.8 range.
A well setup suspension on slicks, you should easily kill him off the line. Besides when you're pullin' the fronts, what good is AWD?
Old Drag Racer
Track: you win.
Street: might get interesting.
I've got a couple of decently powered AWD cars and they're just nasty on the street. At the track my SI SS will run the same times in the 1/8th mile. The AWD advantage is on an unprepped surface, not at the track.
2700lbs 780hp audi awd 4x8" slicks vs 3630lbs supercharged camaro on 325/50-15 dragradials....
http://www.nonameracing.se/movies/20...inge060527.wmv 12mb
Originally Posted by LS1 Sounds
I have pulled several AWD cars off the line with a stock 10 bolt, M/T ET Drag radials, a Vig 2800, boltons, and 311 rwhp.
EVO's do not 60' like an old school DSM. It takes a LOT of suspension work (coil overs) to get a 1.5 60' out of one of them, where my old Talon did 1.53 regularly on stock type suspension.
You should be able to out launch him and never look back.
Al
Al
You may want to consider some suspension mods (lcas, t.a. etc)...and don't think that you are in for any sort of easy win as he probably has a better power to weight ratio.
I'd prefer to see you win so you might get yourself some insurance like a small shot of nitrous.
Im still stock internally....im broke after buying my9 inch haha...damn college!
Retired Street Racer
Al
Al
