Speedometer in f-body with turbo 400
There are companies out there that make a tail housing for the 400 with the VSS in it, I think Rossler is one of them. You can also tap into the wheel speed sensors to get a reading but you lose the ABS, PM sux2bu about that.
I ruin the end of films...
You'll need the pickup and reluctor ring from a 454SS to make it work. Not sure about the LS1s, but that's all you need for the LTx cars. I don't have the GM part #s though.
I just switched to a mechanical speedo and ran a cable to the old pickup.
Originally Posted by minytrker
It has a differnt rear witout abs so that doesnt matter, but there are no wires going to the rear at all in this car.
Originally Posted by ThaLS1KidII
Like someone else mentioned, it is the front sensor that you tap into and sux2bu can give you all the info you need to do it.
Can you do this with LT1 cars also?
i got a new tailshaft and reluctor wheel from a tranny company in texas. Slide the wheel on the output shaft, put the tailhousing on, plug in stock sensor. Have a speedo that works like stock.
Restricted User
