gaskets
Originally Posted by Beast96Z
Stock gaskets are only $25 bucks from the dealer. Never reuse a gasket unless they are intended for that purpose, and stockers aren't. Once there crushed, there done.
So i figured if i could save a few bucks....
Anyone know the cheapest place to buy cometics?
$25 is for the pair. So you still have $25 for beer. Cometics will run you close to $200 bucks about anywere you get them. Haven't seen to many people with deals on them. Not to mention the risk of leaks. I had bad luck with cometics.
GMPARTSDIRECT has them for $25 each...
Gotta a sponsor link? PM me if you can not post a public link to it...
Are you wanting the graphite or the MLS? I believe the MLS's were the cheap ones, although the graphites weren't expensive either. www.sdpc2000.com is probablly going to be the best place. Contacting Mike (bg-sdpc) will net you the best results. Here's his profile: https://ls1tech.com/forums/member.php?u=57241
