32 PSI Oil Pressure, HELP!
just had a new cam & pushrods & springs & Head Gaskets & new Timing chain, put in my 2000 Formula, I just bought the car in march & noticed the car had low Oil Pressure, On start up after sitting all night when I would start the car, The car would idle around 40 psi on the stock gauge for the oil pressure. But after about 30 mins or so once the car had warmed up it would drop to about 32 psi on my stock Oil Pressure gauge.
My question is 32 psi Oil Pressure something I should be worried about or is this normal for my car
The shortblock has 103,000 miles on it & has had a fair amount of Nitrous through the motor from the last owner.
Here is a list of my mods!
Stage 2 4l60E Transmisson with TCI Flexplate all upgraded internals was rebuilt by Phoniex Tranmission
Yank Pro Thruster 4400 Stall Converter w/shift kit & Trans cooler
B&M Deep Tranny Pan
Ported stock LS1 Heads
LS6 Intake
Shaner TB
42lb Injectors
Walbro 255 In tank Fuel Pump
NEW Patriot Gold Valve Springs (zero miles)
NEW Hardened Pushrods
NEW Lifters
NEW Timing Chain
NEW Cam Motion Custom Cam Intake is a 600+ lift on Intake & Exhaust with a 238 -242 Duration with a 115 Lope Seperation car put down 420 RWHP on motor
Hooker Super Competeion Long Tube Headers 1 7/8ths
Texas Speed True Dual X-Pipe with Bullet mufflers Dumped
Subframe connectors
Super Slot Rotors
Hawk Pads
New Eibach Pro Kit Springs
QA1 Coil Overs up front
QA1 Adjustable shocks in the back
MSD Wires
Carbon Fiber Lid Drilled for a 5177 NOS KIT
5177 NOS Kit
Window Switch
Remote Bottle Opener
Bottler Heater
NOS Purge coming out the Nostrals SET UP CLEAN NO LINE'S UNDER THE HOOD
3.42 gear out back
T/A Girdle
Tuned & built by Simple Quick Racing out of Fort Worth, TEXAS!
10 Hideaway box so you can still store your t-tops & Rockford amp
WS6 Aftermarket Ram Air Hood
Torqe Thrust II Rims Powder Coated Black w/chrome silver lips
Brand New M/T 17 11.5 ET Streets
New Hawk Break Pads
Slotted Rotors & drilled rotors
Thanks guys!
Seb
B&M Deep Tranny Pan
LS6 Intake
Shaner TB
42lb Injectors
NEW Lifters
NEW Timing Chain
Subframe connectors
Super Slot Rotors
Hawk Pads
MSD Wires
5177 NOS Kit
Window Switch
Bottler Heater
3.42 gear out back
T/A Girdle
New Hawk Break Pads
Thanks guys!
Seb
1 Post
well part of the lower oil pressure is due to it being summer and hot as hell. I dont think you have any thing to worrie about just when u get the chance just get a ported ls6 oil pump.
Thomas
Thomas
Originally Posted by mattr228
it could be the Hawk Brake pads or quite possibly the T/A Girdle
like mentioned above , was this at idle , or at what RPM range did it drop to 32psi?
What can I do to get the car to idle at 40 psi all the time in this Texas Heat. Also is installing a Ported LS6 Oil Pump something I can do in my garage on the weekend & how involved of a project is it?
Thanks for all the history on your car. That can make a difference when you diagnose an oil pressure problem.
Do you really think 8 psi....32 to 40 is going to make a difference. I mean seriously, you've got to be kidding...RIGHT?
I was under the impression that if my Oil Pressure was under 40 psi that this was a red flag & should be worried.
No I was not kidding,Yes I did think 8 PSI would make a diffrence by the way! Never hurts to ask then learn the hard way! I am out maybe 10 mins of time to give myself a peace of mind.
LS1TECH Sponsor / 7 Second Club
Originally Posted by mcowart
i was told that you need at least 10 psi per 1000 rpms..and you are safe..my idle psi is about where yours is...it should be fine..
Originally Posted by FIREHAWK #07
damn my lt1 is @ 32 psi at WOT j/j but really lt1's have some low oil pressure....
mostly all 23* motors pull less pressure with a stock pump... high volume pumps are good up grades... just by stock pump and put a high pressure spring and your good to go on the lt1
