Retune needed after Heads/pulley install since Cam only tune??
Old 06-10-2006, 12:28 AM
kazfan30's Avatar
Default Retune needed after Heads/pulley install since Cam only tune??
Had RWTD perform a Cam only tune a few months back, since then i have added PP 243 heads and a pulley, can my tune be off now??? Because i only gained 3 tenths and 2 mph since head swap at the track 12.50's to 12.20's and 109 to 111....car still not performing how it should
Old 06-10-2006, 08:03 AM
ringram's Avatar
Yep, get a retune for sure. Will help to some extent. You might want a proper dyno tune too. Should gain you more than a mailorder one.
Old 06-12-2006, 08:48 AM
Jpr5690's Avatar
yea you should be lean from the increase in ve allowed form the better heads
Quick Reply: Retune needed after Heads/pulley install since Cam only tune??
