my car is all f-ed up...help!!
i took my camaro to the shop yesterday to get the clutch checked. on the way it started slipping like carzy and i could not even get over 65 every time i would accelerate fast it would slip. so when we put it up on the lift we come to find that i have a oil leak in the intake gasket? which is why the clutch is messed up im also going to need a new hormonic balancer and belt and he also thinks i may have a problem with the pin in the rear which may need to be replaced in a couple of months.
so im going to pay about 300 for the hormonic balancer
plus about 250-400 on a new clutch
and he said he would get back to me on how long and much it will take to fix the oil leak(is that a hard thing to do?intake gasket?)
I'll be the first one to tell you that you will not need a Harmonic Balancer, that is one of them Mechanics that should get a foot up his ***. Belt maybe.. Pinion in the Rear, no. The Oil leak in the Intake is simple, pull the Intake off, and re-silicone the back and front, that is all the Seals are.
no i know this guy he is one of my friends dad's and i went under the car with him and he showed me that not only was the hormonic balancer wiggiling a little bit but the rubber piece inbetween the two pieces oe metal was deteiorating. and the belt i could clearly see was dryrotting.
how much or long do u think it would take to do the oil leak?
and you car hear a sound in the rear, thats what he thought it was....
i had a leak at my intake manifold so i pulled it this weekend. it took me a little less than 2 hours to pull it off. then about another 2 hours to thouroughly clean all the surfaces and intake then just silicone it up and put it back on. id say it could be done in 6 hours and you could really save yourself some time if u go ahead and pull the fuel rails, vacume hoses, coolant hoses off the intake and all of that other stuff before u start removing the intake bolts. and be sure the note where each bolt was at because there are 6 bolts (2 sizes) and 6 studs (5 short, 1 long) all the bolts are 9/16'' and then there are some more bolts on the back like on the egr that are 1/2'' then the normal small bolts like 7mm - 10mm.
i had the harmonic balencer fall off my jeep it was 2 peices and the rubber between them was dryrotted i was pulling out of my friends driveway and it fell off and rolled down his driveway.you could change that yourself though it would take like 30 min.
yeah ill probably do most of it myslef maby with some help from his dad but what do u think about while im talking the intake manifold out, i paint it red????? what type of paint should i use and sould i use a clear over top?
