torque settings for a FAST 90
i lost my sheet.. for those of you who have your install sheet still, can someone tell me what the torque setting are for the new valley cover bolts, the bolts that hold the manifold together and then the settings for the actual long intake mounting bolts.
steve
steve
right out of the fast manifold destruction sheets
valley cover button heads 18 ft/lbs yes ft.
coolant crossover 106 in/lbs
fuel rail 89 in/lbs
throttle body cable bracket 89 in/lbs
manifold to head bolts 2 passes 30 then 50 in/lbs
manifold to manifold nuts and bolts 50 in/lbs
fuel rail 89 in/lbs
fuel rail 89 in/lbs
fuel rail 89 in/lbs
Manifold to head bolts are 2 passes, first pass at 45in/lbs and second pass at 89in/lbs.
Throttle body to manifold is 50in/lbs.
