Hooker gave cruise cable burns in a bad way
The slip fit from my Hookers LTs and cruise control cable decided to get togther, think the primary from the LT gave it an STD because it burned it prety good. Not sure if it works any more, but I ended up moving the cable out of the way and hoping it stays away. If the cables a gonner, is it prety easy to just swap the cable out?
Originally Posted by FIREHAWK #07
lol same **** happened to me!!! eventhough i can see the inside of the cable; it still works!! I use the cruise control eveyday going to work and back !!!
Originally Posted by BizZzatch350
You just move it out of the way?
Another thing that got burned.... was my brake line!!! The removeable primary was rubbing against a steel brake line......!!!! So after a few weeks, on my way home from work i push on the brakes and my brake line comes on!! That scared the **** outtta me!!!
yup.. just moved it outta the way...
Mines wont run but that bitch is damn close
