PCM Diagnostics & Tuning - Rough Startup After Cam
00transamnh
06-18-2006, 03:06 PM
is it usual that the car wants to die out when you first start it up with a new cam in it? My car likes to die out for some reason (even after getting tuned). After about 15 seconds of running it idles perfectly
anyone have any ideas?
ringram
06-18-2006, 04:49 PM
it might be usual if you have a bad tune.
If you have a good tune, then its not.. Issue is likely to be running airflow (desired airflow in efilive)
Can also be a few other things, like timing and some of the other startup parameters (cranking, initial enrichment etc) but more often than not its running airflow table.
technical
06-19-2006, 11:41 AM
Sounds like the initial enrichment timer considering it takes ~15 seconds to straigten out. I wonder if something is off a bit causing the PCM to throw the wrong amount of fuel.
Does it do this during a warm restart, or just a cold start?
00transamnh
06-20-2006, 07:04 PM
doesnt matter... can be cold or warm... does the same thing
irritating as shit tho, noone elses cammed car does this
Black02SS
06-20-2006, 07:06 PM
Alsmost sounds like the tune as ringram stated.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
