How to shut off or desensitize the knock sensors with LS1 Edit?
Just curious, cuz i'd like to shut 'em off or desensitize them, cuz i'm gettin a lot of false knock on my launches and it's killin me with knock retard, leavin a lot of power on the table! Any help is appreciated, thanks guys!
just turn all your max spark retard table to all zero, also set the knock retard decay/attack tables to zero. Even if you pick up false knock still the PCM will be unable to pull any timing. Just make sure its false knock 1st or you could hurt something.
Disable Burst Knock, maybe look at leaving the rest. BKR is responsible for a decent amount of logged KR on throttle transitions. If you are gettting sustained knock you certainly dont want to zero that out.
