Anybody have big cams with milled heads
Old 06-19-2006, 07:02 PM
Bad N Black's Avatar
Default Anybody have big cams with milled heads
I have a cam in now. I would like to go bigger. The heads are LS1 heads milled .015 with 2.02in & 1.59ex valves. The cam I have now is 224/224 563/563 114.9 lsa. I would like to replace the cam with SLP 236/236 590/590 112 lsa. Thanks
Old 06-20-2006, 12:09 AM
MountainMotor's Avatar
When you start going very big you have to watch your P/V clearance. You could have the pistons flycut if need be.
Old 06-20-2006, 02:22 AM
dirty2kTA's Avatar
personally i dont care slp products when it comes to internals or blocks, but there is formula that i will allow to know for sure on the p to v clearance. if your current springs are weak then you will want the replace them because even if the cam of your choice has clearance its possible to still hit a valve in the high rmps due to the fact of a weak spring not be able to pull the valve up as it should.
Old 06-20-2006, 07:52 AM
GuitsBoy's Avatar
I have a moderate cam, 232/234 .595/.598, stock valves, and heads milled .040. I had to flycut. Notching the pistons about .090 yeilded me about .165 P to V clearance.
Old 06-20-2006, 09:59 AM
RALLDU's Avatar
Have milled heads, with 575 590 cam, oversized valves and works fine. no problems here
Old 06-20-2006, 10:51 AM
KGSloan's Avatar
it's the duration that is the problem with p/v clearance, not lift.
with those cam specs and head specs you would have to check, and my guess is you would need to flycut. my $.02
Old 06-20-2006, 12:35 PM
Could you tell me what your duration is?
Old 06-20-2006, 07:17 PM
dirty2kTA's Avatar
old set up:
y1 cam .595/.608 234/240 113
mti stage 2 5.3 liter heads
stock cube
no problems whatsoever until the nitrous got a hold of it.
Old 06-20-2006, 07:33 PM
Originally Posted by dirty2kTA
old set up:
stock cube
How big were your valves? Did you milled the 5.3 heads?
Old 06-20-2006, 09:47 PM
Quik's Avatar
how about the TV2 112 with flat tops and milled .020 heads? im looking to bump my SCR to 11.4 and figured if i can cut the heads that much i should be about that ratio im looking for. will i have to fly cut them
Old 06-21-2006, 08:00 AM
allngn_c5's Avatar
Had to flycutt my pistons to achieve proper PVC. Good luck on your future setup.
Old 06-21-2006, 08:55 AM
RALLDU's Avatar
CAM SPECS ARE
228/236 @ .050
575/590
112 lsa
MANLEY STAINLESS 2.02/1.60 VALVES
Old 06-21-2006, 06:43 PM
CAM SPECS ARE
228/236 @ .050
575/590
112 lsa
Thanks for the info.
Old 06-21-2006, 08:42 PM
dirty2kTA's Avatar
2.02/1.55 they were not milled
Old 06-22-2006, 06:43 PM
Thanks again.
Old 06-22-2006, 07:00 PM
waterbug1999's Avatar
I notched my pistons .085" with my current set up (.040" gasket). Not hard to do at all.
Old 06-23-2006, 07:24 PM
What are the specs on a g5x3 cam. I would love to notch the pistons. But that would require me to remove the heads. I can't do the heads again.
Old 06-24-2006, 12:36 PM
Its bigger then the one you mentioned in your 1st post. If I were you, I would make some phone calls to some of the vendors here on this site and ask and see what they say. They might have done something close to what you are wanting to do. Im sure at the end, they will say it might be close and just check it. But to check it, you would have to pull your heads, which you stated you did not want to do. Thats the only "sure" way.
Old 06-26-2006, 07:26 PM
Thanks waterbug and to everybody here at the greatest web sight in the world.
Old 06-26-2006, 07:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It is a combination of everything that makes up valve events that determine whether or not you are going to have a clearance issue. Not based on lift/duration alone.
