car dies when ac is turned on
Old 06-19-2006, 08:27 PM
6-Speed Terror's Avatar
Default car dies when ac is turned on
my car turns off when the ac is turned on i read that u need to tune on the ac on airflow add grans/sec what is a good number to add on to the table so that the car does not turn off
Old 06-19-2006, 10:40 PM
ZL1Killa's Avatar
have you increased the airflow.... i see in your post... nevermind you are on the right track.
try recording your car with the scantool and look at Desired airflow and actual airflow
then turn the ac on while logging and you will get a glimpse of what it wants... then go from there. if you didn't get a glimpse on the scan tool then increase by say 2grams at a time? I haven't had to do this yet so....its just a guess
Quick Reply: car dies when ac is turned on
