transmission pressure gauge
Old 06-22-2006, 08:38 PM
rocmemphis's Avatar
Default transmission pressure gauge
I purchased an in car tranny pressure gauge for my 4L60E. Unfortunately the sender unit will not fit in the stock pressure port location. If I were to tap a hole and install it in the pan would it still work?
Old 06-22-2006, 08:52 PM
buffman's Avatar
probably not. What size is the sending unit. pressure port on case is 1/8" NPT. Get an adapter..
Old 06-22-2006, 09:25 PM
rocmemphis's Avatar
The problem isn't the adapter. The sending unit will not fit between the tranny and the tunnel.
Old 06-23-2006, 12:23 AM
buffman's Avatar
Ahh. I forgot theres less space on an F-body underneath then my big fat B-car. If you cant mount it vertically why not get a 45 or a 90....
Old 06-24-2006, 08:34 AM
koolrayz's Avatar
I have a 90 that i put on when checking pressure. its a real b#tch to get at when the trans is installed but works.
