TSP Giant Cam, PP LS6 Heads and stock SB
I have seen on other website that larger cams like the T-Rex were used on stock head motors. I would like to know if the Giant Cam can be used with Patriot Performance Stage 2 LS6 unmilled heads, and a stock 2001 short block. Will there be issues of the valves hitting the pistons? This would be a N/A setup.
I actually talked to tsp about the very same question and they said that thie biggest cam they would recommend for a stock bottom end would be the ms4. anything bigger will be breaking alot of parts.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Any advice that you get over the internet take with a grain of salt.
Except for this:
Always double check for your own peace of mind to be sure that everything will fit properly. And just because it fits doesnt neccesarily mean that it is any better. You might want to make sure that this cam is going to be the route that you are wanting to take.
Except for this:
Originally Posted by Gold Phoenix
Could you clarify alittle more?
Either aftermarket pistons or flycutting would be needed.
That is actually the cam I am running in my 402.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The head are Patriot Stage 2 LS6 heads that have not been milled. The chamber was re-worked to 59cc without milling. This would give me a 11.3:1 CR.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Mr. Luos
I personally wouldn't run hydraulic with that cam in a stock cubed motor. Solid roller.
Originally Posted by orangeapeel
I was going to say that it seemed like a stroker profile.
2300-6800 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle! Custom tuning required
THIS CAMSHAFT IS DESIGNED FOR BIG CUBE ENGINES!!
