Fast 90 / NW 90 worth it for me?
I was just wondering if it would be worth the money to get the fast intake and the NW 90 TB? with my current modifications (listed below, dyno numbers are on a stock TB )... on a stock displacement engine. I heard ALOT of good things about it, but when i got the H/C done at MTI, the guys there said i shouldnt get the Fast90/90 (cant imagine why they would say that, its just more money im giving them). They said that i could possibly lose alot of low end power i believe they said. Something about a vette had it done there and lost alot down low, and just had the 90/90 removed.
So basically is it worth it to get the Fast 90, maybe get another 20ish rwhp or should i just stick with what i got and spend the 2 grand on a 12 bolt rear?
Any input appreciated, thanks
Id stick with your current setup. Unless you had the LS1 intake yes, but you got the LS6. Not much bang for buck trying the 90/90....then again its your money your car, but I would not.
do u have a LS6 intake??if not i would go that route and a ported throttle body..it will give you good gains...the 90/90 would help but imo it only comes into play after 6500 rpms..for extra gains with it..if you are reving to 7000 i would get the 90/90 if not then i wouldnt spend the money...just my.02
thanks for the input guys
Its a pretty mild cam, not very big. And yes it does have the LS6 Intake now with an MTI ported/polished TB.
I guess its not worth it, i rarely drive the car at that high of RPM's, if i do its only up there for a very breif period of time
