catch can setup !!!!!!!!!
Old 06-29-2006, 12:19 AM
zrater's Avatar
Default catch can setup !!!!!!!!!
do u guys use the filter in the seperater or take it out, mine seems
to be getting pretty soaked with oil..........................
Old 06-29-2006, 12:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Take it out man.
*EDIT* You might want to work on your signature...
Old 06-29-2006, 08:18 AM
iamsickofitall's Avatar
Originally Posted by orangeapeel
Take it out man.
but what if he's got two cars with the same mods that turn the same times
Old 06-29-2006, 10:55 AM
robertbartsch's Avatar
OK, I have a ton of catch can experience.
The best deal is a BIG *** PVC pipe about 2 inches wide and at least 12 inches long. Buy the PVC pipe at Home Depo and a rubber plug (top), brass fittings, and tubing too.
Do not use filters with this - it is not needed. The extra can volume does wonders to mitigate the negative pressure and keep any crankcase oil from getting into the intake.
Make sure your two connections are (i) near the top and (ii) near the middle of the PVC can.
Mount the can near the radiator on the passenger side.
This set up is simple, cheap and VERY effective.
Old 06-29-2006, 05:01 PM
zrater's Avatar
anyone else take filter out , i dont think its doing any good..
Old 06-30-2006, 12:06 PM
MiaSSmaro98's Avatar
so i can make a catch can from homedepot?wats needed?
