how to fix banging?
how to fix banging?
just got my car back and it sounds awesome, but when i pin it either the y pipe or the drivers side header is banging the floorboard, im really not sure which one it is. is this common? and how can i fix this?
-poly motor omunts
-poly tranny mounts
-Mufflex Y pipe hanger
All are pretty cheap and available from Thunder Racing. Although it's a shame you didn't do the mounts when you had the exhaust off.
Originally Posted by TylerDurden28
+2 on that!
+3 on this.
what i did was wrapped some transmission cooler hose around the full diameter of the pipe where the pipes are touching any floor boards or metal or whatever. then i took a tie strap and slid it through the trans. hose and tightened the tie strap. i did this on 5 places. works great
