LS6 stock peak HP/torque range?
Old 07-04-2006, 08:50 AM
Cpig's Avatar
Default LS6 stock peak HP/torque range?
At what RPM range does a stock 2001 Z06 (except LT headers and CAI) see peak HP and Torque?
Also what should I set my A/F ratio to at these peak ranges?
Thanks,
Joe
Old 07-04-2006, 10:13 AM
300bhp/ton's Avatar
eh?
If you're messing about with the fueling you really need to go have it dyno tuned on a rolling road. You'll then be able to see where it makes PEAK numbers.
But on their own they do you no good at all as a stock LS6 is likely to be making about 90% of its PEAK torque by 1500-2000rpm.
Old 07-04-2006, 11:07 AM
AU N EGL's Avatar
The T1 racing corvettes with stock LS6 motors, and stock air intake and stock headers and cats, then straight pipes are dyno tuned to 385-387 wrhp, 375-380 wrtq with peak HP at 6300 and red line of 6700. and a flat tq curve from 1500 right up to 4800
Quick Reply: LS6 stock peak HP/torque range?
