power window wont go down
Old 07-09-2006, 06:01 AM
Charlie Hustle's Avatar
Default power window wont go down
i just recently had the motor changed on my drivers side, and it has been working fine. all of a sudden it doesnt do anything. before, when it was going bad it would at least go down slowly and get stuck, or creep back up, etc. now it does nothing. the passenger works just fine. i checked the fuse and it looks fine. does anyone know what it could be? thanks in advance
Old 07-09-2006, 06:49 AM
02Z28LS1's Avatar
sounds to me like the switch itself may have died on ya, or possibly a connection came loose inside there.....
Old 07-09-2006, 11:28 AM
Greed4Speed's Avatar
Connection, fuse, switch or relay.
Old 07-09-2006, 11:41 AM
kickassT/A's Avatar
if that all checks out, try taking the door pannel off and tapping on the motor with a hammer... sometimes the brushes get stuck and the motor wont do anything. just tap it lightly a few times and it free up and start working
Old 07-09-2006, 01:26 PM
TT-TECH Veteran
Inspector12's Avatar
And if that doesn't work try replacing the motor again LOL! They go out very easily.
Old 07-09-2006, 03:08 PM
if all that doesnt work....ill be giving you a call again
Old 07-09-2006, 03:09 PM
where is the relay located?
Old 07-10-2006, 09:40 AM
LawHorn's Avatar
i told you what to do slam the crap out of your door. That happened to me all the time in old blue. haha
Old 07-10-2006, 03:23 PM
tried it...didnt work. trey you need to list the beater in your sig
Old 07-23-2006, 08:06 PM
Fuse is in the fuse box.
Relay is above the throttle. Little box ~the size of a cigarette pack sitting in a metal "pocket" on the inner side of the firewall. Just lay on your back and you should see it.
