4l60E Bellhousing Questions
Old 07-10-2006, 06:49 PM
Aaron's Coupe's Avatar
Default 4l60E Bellhousing Questions
I am doing LSX swap into a street rod and have a couple questions. I am building a 6.0L and using a 4l60E trans. I got a real good deal on a 4l60e and have an issue with the bellhousing. The trans came out of an S-10 but as you guess the bellhousing is wrong (it is too small). I assume that all I have to do is get a replacement bellhousing (but I need a part #), is there anything else needed? if so what are these part #'s.
I have done some research and it's my understanding that all the 4l60e are the same with the exception to bellhousing and talehousing.
Old 07-12-2006, 04:18 PM
t t t
Old 07-12-2006, 04:58 PM
8a8mfh's Avatar
Find a transmission hardparts supplier and tell them what you're doing. They have all the interchange information, plus they should have all the parts in stock. Good used of course but for a non wearing item like a bellhousing they're most likely good as new.
Old 07-12-2006, 05:01 PM
Yank's Avatar
You will need to change the :
bellhousing, input shaft,clutch housing as the number of clutches is less in yours, the stator support as the LS-1 style is longer, as to go with the longer input shaft
and the pressure control sol.
I have theLS-1 belhousings in stock if you need one.
