How easy???
Old 07-14-2006, 11:31 PM
Z28LS1camaroguy's Avatar
Default How easy???
Well i am wanting to take the Valve covers off and check the pushrods and rockers, is it easy or am I gonna run into problems?? i know how to get the injectors out, coils off, and i consider myself an intermediate when it comes to engines but im not to sure on what to torque the valve covers back to??
Old 07-15-2006, 12:23 AM
jrp
SN95 Director
jrp's Avatar
remove coils
remove vavle covers
remove rockers
remove pushrods
inspect and replace as needed
install rockers tq'd to 22ft lbs. turn motor 180* and torque down to 24ft-lbs
install valve covers hand tight
install coil packs hand tight.
go to ls1howto.com in the cam install section if you need a pictured walkthrough. also, in the FAQ (sig) there's GM's way on how to install and tq down the rockers.
Old 07-15-2006, 12:53 AM
zo6vetteman2003's Avatar
Are you inspecting the rockers and pushrods or removing them?
Old 07-15-2006, 07:07 AM
Viper's Avatar
Valve covers are 106 in/lbs or 12N-m.
Old 07-15-2006, 07:33 AM
99SilverZ's Avatar
Here are good instructions with pictures,
http://www.ls1howto.com/index.php?category=0
Old 07-15-2006, 11:08 AM
im just inspecting them, just to make sure a pushrod isnt slightly bent or anything.
Old 07-15-2006, 01:28 PM
It may be difficult to detect a bent pushrod with them installed, so removing them is recommended. If one is bent, what then? One solution is to upgrade to an aftermarket 1.7 ratio roller rocker with chromemoly pushrods while you are at it. You will have to reset the valvelash when you are done, not hard, as much as time consuming for bleed down of the lifters. If you have never done it before, we all can help, but it is pretty straight forward. You get a trouble free valvetrain and some extra power.
If you do this, you will want new valvesprings and a cam to go with it. hehe.
