Procharger single fan shroud? (+ add #2 fan)
I have a d1-sc Procharger LS1 supercharger system installed on my 01 m-6 SS.
OK i am using the procharger sheet metal fan shroud with a Spal extreme 16"
replacement high performance fan,
I realy want to install another smaller spal fan next to the 16" spal extreme, and i heard of guys doing this,
i want my low duel fan speed back,
the single 16" fan only comes on at full blast now, i want to add another fan, so it will work just like the twin stock ones did.
what size fan did you install next to the single spal 16" fan?
and also the part # if you have it.
Let me know if you wired it like the stock set up and how well it worked over the single 16" fan comming on at only full blast, what temp do you have the low speed turning on at and also the high speed .
thank you for your help.
