just installed SLP lid!!
it only took less than 10 min. everything went in good. really tight fit too. i was able to get it lined up and able to clamp it down without having any clamps pop off. good tight fit. i didnt get to go for a test run to feel the sotp effect. but overall damn good product!! i would recommend this lid for anybody or newbie looking for a first mod. if only tbyrne can hurry up and send out our magnaflow catbacks already..
Originally Posted by TXZ28LS1
whats up iron sights, well i wasnt sure how the air hose would go. so i just bolted it on the tubing that comes with it.. but it is kinda irritating seeing it just sit there.
I think the SLP lid is good as well and it looks good when you pop the hood. I would also recommend this lid as a first mod. It was my first mod.......
Tech Resident
as long as you don't do the smoothe bellow it will likely continue to fit good. it seems like everyone with fitment issues has the smoothe bellow and people with the stock bellow have a perfect fit every time. i have a stock bellow and my SLP lid fits like a dream. awesome quality!
Instead of making a new thread I'll just revive this one. I've had my slp air lid for a while now and I've never really gotten it to fit really well. I do have the smooth bellow which ChocoTaco says is the source of my problem but unfortunently for me I can't find the stock one. However, I've looked at some other sources. Is it necessary to install the gasket that comes with the K&N filter around the lid? The lid seems to fit better without the gasket, which makes sense, but I'm worried that if I take out the gasket unfiltered air would get past the cold air intake/filter through the slits by the sides.
Another thing, the bottom of the lid neck is rubbing on the radiator support, anyone know how this might effect the lid-filter seal?
something else you can do is get a bigger fitting bellow or boil the one you have....i went the fernco mod way seeing as i wouldnt blow 50 bucks on a bellow...i boiled mine and it fit on the maf perfect.....thats another thing, what the hell are you people talking about.....the bellow doesnt touch the lid, so how can there be a fitment issue? if there is one is how your maf fits into the bellow...or the bellow lips up with the tb
The bellow slips over the MAF and TB just fine. True, the bellow does not touch the lid itself, but it does create a fitment problem. The lid itself with no MAF or bellow fits perfectly with no slits. With the addition of the bellow in my case, maybe because of its flexibility (or lack there of) along with its design kind of "twists" the MAF/Lid unit out of place, therefore creating a fitment issue. What i've done to mostly correct the problem was to install the bellow onto the TB first and then force the MAF/Lid unit onto the already fixed bellow and tightening the worm clamps while forcing the lid in place. However, there it is still not fitting as well as it should be, there are pretty big slits around the lid and over time and heat the forced position begins to slip and fitment worsens.
Originally Posted by BlackBADaSS02
I have the SLP smooth below along with the SLP Lid. I didn't have any fitment issues, it was just a little tight getting it on.
i have never had the stock bellow as mine came with a smooth bellow,when i bought it, but no fitimet issue's at all with it. i think the people having issue's may need some "special" help. or some muscles. it requires a tiny bit of pushing but nothing to complain about.
