knock sensors / harness
i have a code for the knock sensors so i changed them both out but the code is still there. i now have a new knock sensor harness to hopefully fix the problem but need to know if this will remedy it, i dont want to remove the intake again for nothing.
Knock sensor codes are different for front or rear. Sure you didn't pinch the harness/connector when putting in new ones? I'd look up the code at www.gearchatter.com for any possible diagnostic steps before removing the intake.
