Who is using 50 weight oil? Come on in!!
Old 07-20-2006, 06:15 AM
99whitews6's Avatar
Default Who is using 50 weight oil? Come on in!!
What engine? Any oil consumption?
Reason I ask is because I initially put 30 weight in my new 408, burned 1.5 quarts in 1100 miles. Put in 40 weight and still burning oil but not as quickly. I am trying to determine if it would be appropriate to put 50 weight oil in. FFHP didnt give me a build sheet but said the clearances were probably pretty loose.
Old 07-20-2006, 04:37 PM
Haans249's Avatar
If the clearances were "probably pretty loose" then why the hell did they send you the engine? Thats pretty f'ed up if you ask me.
Old 07-20-2006, 09:11 PM
ArcticZ28's Avatar
LS1Tech 20 Year Member
I agree with Haans, you should be able to run M1 5w-30 (somewhat thin) without any problems.
Old 07-20-2006, 09:51 PM
DrkPhx's Avatar
It's not unusual for strokers to have looser tolerances compared to a stock block.
Try 5 quarts of 10w-30 and 1 quart of 20w-50 (6 quarts total).
Old 07-21-2006, 05:53 AM
99whitews6's Avatar
Could this issue possibly be the valve seals? I did have TSP upgrade the AFR 225 valve springs to PRC springs prior to shipping them. Maybe they didnt replace the seals and just resused the old ones.
Old 07-21-2006, 06:48 AM
AU N EGL's Avatar
15-w50 here. LS6 motor, with 3qt accusump and oil cooler. 10 1/2 qts, change evey two weekends on the track.
No problems. But then all it sees is a road course.
Old 07-21-2006, 07:40 AM
99whitews6's Avatar
Just street driving here. But I beat on it like a road coarse! 6K RPMS everytime I leave from a stop light or stop sign
Old 07-21-2006, 08:08 AM
Michael02hawk's Avatar
Mobile One, 15w50 here also. LS1 stroked block.
Old 07-21-2006, 08:19 AM
Blownramair's Avatar
wsw ls6 race engine here... using m1 15w50... all the time, changed every 100miles or every season, whichever comes first...
J
