Just got my Pace Setter LT's Today!
Old 07-26-2006, 05:39 PM
JuStIn_Ws6's Avatar
Default Just got my Pace Setter LT's Today!
Just got my pace setters in the mail today. I can't wait to put them on!
Old 07-26-2006, 09:33 PM
gameovergt's Avatar
Cool, let us know how the install is.
Old 07-27-2006, 07:23 AM
ravensfan's Avatar
Where did you order them from, and how long did it take to get them?
Old 07-27-2006, 07:43 AM
JuStIn_Ws6's Avatar
I ordered them from byunspeed and it only took like four days. They were fast!
Old 07-27-2006, 09:28 AM
nyteryder167's Avatar
Good luck with the install, just take your time, it's a pretty easy job. You'll love the difference.
Old 07-27-2006, 09:36 AM
gameovergt's Avatar
Are there any fitment issues?
Old 07-27-2006, 11:01 AM
kaell's Avatar
Not issues at all... begin with passengers side, then you do the drivers side in like 1 hour at most when you know how to do it.
Old 07-27-2006, 11:26 AM
Domestic Demon's Avatar
Snap some pics if you can, I'm curious to see how they fit into the engine bay and bolt up to the stock exhaust
Let us know what kind of difference they make after you take it out for a drive
Old 07-27-2006, 04:00 PM
JuStIn_Ws6's Avatar
I'll let you guys know how it goes!
Old 07-27-2006, 06:16 PM
GXPPOWER's Avatar
i got mine we had to unhook the steering knuckle to slide the headers in on the driver side. the passenger side was a cinch!
Old 07-27-2006, 08:42 PM
JuStIn_Ws6's Avatar
Hey thanks for the info. About how long did it take you?
Old 07-27-2006, 08:47 PM
GXPPOWER's Avatar
well i did tsp true dual exhaust install with it all. since your hooking it back to the stock exhaust i would say 3-4 hours if you dont play around and go for one goal getting it installed.
the hardest part is the last 2 bolts on each side of the original headers. hopefully you got some long thing wrenches ect makes it alot easier.
what is cool is if you ever decide to remove the cats ect. the whole #8 plug being impossible to remove is no more. oyu wil be able to reach from under the car alongside the headers.
just dont loose any of your bolts and screws ect .
also once you have them installed. after driving a few time after about 2-3 days check the bolts again. and retighten if needed. the cold and heat will make the botls sometimes loosen. it happens alot. also make sure you spray on some anti sieze to the bolts before wrenching the headers down also
Old 07-28-2006, 02:13 AM
Pwebbz28's Avatar
No need to unbolt the steering knuckle if you jack the motor up just a tiny bit on the drivers side. Also on the same side unbolt the strange piece next to the oilfilter (two 10mm bolts) they will pop right in. Or at least my hookers did. If you dont have a catback get a cutout for sure.
