i entertained myself for 3 min
trying to find out what this switch is for. its on the right side of the steering column between the radio and the column. i was sitting there flipping it for 3 damn minutes trying to see if it turned something on or not. its a horozontal switch.
is it ASR?
is it ASR?
Location: Your girl's back door giving her the long stroke while you're at work
It was put there so people like you would waste three minutes of their life trying to figure out what the hell it does: when it doesn't do anything at all
J/K I have no idea what you are talking about
thats exactly what i was thinking
but theres alot of wires going to the switch so it HAS to do something.
its a 94 Z
its a 94 Z
its not a kill switch for sure... its a factory switch with a square and squiggly lines in it. thats why i thought/think its TC/ASR.
Originally Posted by toofazt
Did you check if it's a kill switch?
Here's how you test it:
1. Find the connection on the back glass (should have a single wire going to it)
2. Unplug it and put a paper clip into the connector and make sure it is a tight fit
3. While holding the paper clip have someone else hit the switch and if it zaps your *** then you know if your rear defogger works
should i have a bucket of water handy while im doing that?
Originally Posted by SS4Matt
LMAO at HerronZ28..good ****** guess lol......
Thanks, I owned a 1996 V6 and there was a blank spot where I didn't have that option. That and I'm a friggin' genius!!!
LMFAO
