GOOD NEWS: The cam fits!!!
Hey everyone. I installed my custom cam today. It's a fairly large cam on a tight LSA, and with my .040" head gaskets I was scared about P-to-V clearance. I threw the cam in, bolted up the rockers, and spun it. No problems at all...spun freely, all valves opened and closed, and no contact between piston and valve at all. I couldn't be happier about it right now.
You need to clay it as these guys are saying, otherwise you may run into PtV issues at higher RPMs. The added momentum may cause you to dump a valve into a piston and then into the cylinder and it won't be pretty...
Then it should be fine. If the cam worked with stock heads and your new heads have not been milled then why the .040 gasket? Did you use longer aftermarket valves? You will be increasing the combustion camber CC/losing compression... I thought the G5X3 was designed for stock heads?
I am not sure why you would be worried about PtV?
Now in my case I have Stage II heads milled .020... So I just presumed you had ported/milled heads...
G5X3 on a 110 with .040 gasket
I would remove and flycut if I were you.
The 112 with stock gasket is allready really tight. I mean tight.
If you don't believe me call LOU at LGM and ask him. (unless you have a clone), but you could ask him though.
Turning the engine over by hand with a hydraulic lifter might not be a good test because it will bleed down and give a false reading. This would lead you to believe you have no PTV issues when you actually might. You need a test spring, solid lifter, and possibly a adjustable pushrod. just my $.02
Originally Posted by 8banger
Maybe I'm naive but I just really don't see how a 234/242 on a 110 could have clearance issues when a 244/250 on a 110 (T-Rex) doesn't...
Nate
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You also have to remember that fittament is based off of valve events. Sure, there is probably a way to get a near .700 lift cam in there (don't take this literally, just trying to prove a point) and have it fit like a dream with a little to scrape by on. It would most likely do you no good unless you are sending the bottom end to 8k also.
Valve Events, Valve Events, Valve Events are what is going to determine "if it fits".
