got my prostars and 325's
hey guys i just got my prostars in (15x10) and my mickey thompson dr's (325's) and what did yall do to get them to fit? i already bfh it and cut the bumpstops off (i know i shouldn't have but i did) but my car is not lowered so do i still need to roll the fender lip? and if so what is the easiest and simplest way? ill try to get some pics posted. thanks guys
You may have to, may not. All these cars are different. The easiest way is to just put them on and check the clearance. You can rent a roller from 69TA if you want to do it right.
i also just got mine, 15x10 7.5bs, 15x3.5 up frt .....325/50/15's mt's
it took 5.5hrs, we grinded and grinded on the calipers and brackets, removed bump stop and cut off where it bolts up, hammered in the front lower fenderwell area, had to cut the lower tip of the rear bumper, and roll the fenders......WWOOOOO...and i also had to run 5/16 spacers because the tire will rub the lower control arms, im going to buy some tubular lowers and then ill remove them. ill post pics as soon as i can
i was really wondering if it was worth it, it was!! LOOKS AWESOME
Originally Posted by Scott(382-$T$)
Why cut the bumper? I used adj. lca's and had no problem with bumper.
well i got them on finally... i kept grinding and grinding and still had to run a 5/16 spacer. but i rolled the fender lips also but its still rubbing a little on hard launches. but the time was well worth it... they look freakin sick!
