Where should i put my o2 sensors?
I was wondering on my lt1 if i should have the stock O2 sensors in the crossover or in the downpipe. And if they must be in teh downpipe is there anyway I could possibly have one o2 run both banks?
I know there is not a lot of support here for the LT1, but this would help in my build
Ok your talking about stock o2 sensors, I thought you were talking about a wideband.
I'm not sure if the PCM will run both inputs off one sensor. Thats something for the LT1 section probably.
But when you get yourself a Wideband you will want it in your downpipe semi close to the turbo, I've been told 3-6 inches is a good range, you also have to have it at a good angle.
As far as the stock o2 sensors, I don't know that it matters too much but I would put them in the downpipe if you can.
hmm so i need to put my narrowband o2's befor the turbo ehh...maybe i will just tune without them lol right now they are aboue 3-4 inches away from the turbo and one reads lean the other one reads rich lol.
Originally Posted by smokinHawk
no put the narrow band o2's as close to the collector as possible.
wideband about 3-6 inches fromt he turbo as stated above.
Any input on this?
Thanks for your help.
