Need Crank Pinned...
At what boost level is this recommended? Can I use/borrow someone's kit? I geuss fill me in a little more, it's just a device that holds a drill bit perpendicular to the crank?
once you use it, you're done right? no need to keep it around?
What does the "tool" do (Just hold a drill bit perpendicular?)... anyone have a pic of it? Who's got one?
The tool keeps the drill bit straight & after that the reaming bit straight. very easy to use & most likely you will use it again when you build the stroker forged bottom end that you will want so you can push more than 8psi at it.
Originally Posted by 67Firebird455
LOL, that's an excellent way of looking at it. I bought my rotating kit with it already drilled. Not much of a need for it with my turbo though. Poor SC guys! =\
