scatter shield
scatter shield
I did a search and it did not help. Does anyone have a scatter shield that bolts right up to the engine and tranny with no modifications. I have seen the one from thunder racing but by the look of it, it looks like the LT1 scatter shield. If anyone knows anything please let me know as soon as possible. thanks.
Search on McLeod Bellhousing. Plenty of info.
https://ls1tech.com/forums/showthrea...od+bellhousing
There's one thread.
I have it. You do have to grind down a bit of the oil pan, maybe clearance the starter, and check the bolts that come with the kit (mine were STD - the block holes are metric). Other than that, it's pretty much your typical "well this is a pain in the ***" LS1 work.
There's one thread.
