Does tranny fluid go in here?
Old 08-06-2006, 11:12 AM
SmokinHot98's Avatar
Default Does tranny fluid go in here?
I just changed my tranny fluid out to Royal Purple a couple weeks ago and upon chnaging out my shifter 2day I noticed a small puddle of fluid in this area:
Am I supposed to put fluid in here? If so how much?
Thanks again
Old 08-06-2006, 11:32 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
you can fill your whole tranny from there
Old 08-06-2006, 11:34 AM
But im only supposed to go as high as the fill plug right? So if thats the case then, no?
Old 08-06-2006, 02:23 PM
BriancWS6's Avatar
It's just an easier way to fill the tranny than having to use a rubber hose snaked through the engine bay, or pump from underneath. Just have someone watch for the fluid to start trickling out the fill plug while you add the fluid.
Old 08-06-2006, 04:33 PM
NVR_SPDS's Avatar
Thats how i filled my tranny. I just pulled the fill plug, and poured the fluid in the top, until it came out the fill hole. Easy to do.
Old 08-06-2006, 05:42 PM
thanks guys for the replies. I relized it after I added the little bit of fluid into from a bottle I had. I really appreciate the replies
Old 08-06-2006, 09:52 PM
deejaydaze's Avatar
Royal Purple.....<3
