98 style coil packs on 99+ valve covers
if you mean 1998 coil packs on 1999= valve covers then YES. The 99+ valve covers must have the coil brackets though. The coils will mount up to the brackets no problem. 98-02 are the same
So the answer YES !!!!!!!
Yeah, they're pretty much a bolt on. I think one coil per valve cover needs to be turned over so it will bolt up and you may want to reroute the wires to make it pretty. Also, if you buy the '99 up brackets new, and your retaining screws/bolts from the old valve covers won't thread themselves into the new brackets (the new ones are not tapped from the factory) you'll need to go to Sears and buy a M6x1 tap and thread the new brackets. (about $7 for a skin packed tap & drill ) The bracket P/N is 12563299 and they're $13.51 a piece from Scoggin Dickey.
