PCV catchcan
Old Jun 15, 2005 | 12:18 AM
Blue Falcon's Avatar
Default PCV catchcan
Where can I get one? What kind are you guys using?
Old Jun 15, 2005 | 12:35 AM
Also, did too much oil cause you car to misfire alot
Old Jun 15, 2005 | 01:03 AM
jrp's Avatar
jrp
SN95 Director
https://ls1tech.com/forums/showpost....6&postcount=52
Old Jun 15, 2005 | 08:22 AM
Z'mnypit's Avatar
Im using a Home Depot model.
Old Jun 15, 2005 | 09:17 AM
jrivera04's Avatar
I have the AMW catch can and couldn't be happier.
Old Jun 15, 2005 | 09:21 AM
King James's Avatar
I'm happy with my AMW.
Old Jun 15, 2005 | 11:46 AM
Bill's 02 Z-28 SS's Avatar
Hi Folks
I just received my AMW catch can - looks very well made and should do a good job. The did all the engineering/Fab for you, so why not use something that will work. I am going to install this weekend - should be a piece of cake.
Bill
Old Jun 15, 2005 | 06:35 PM
WILWAXU's Avatar
Originally Posted by kenkaru
I searched on forums for other cars (rice) and found that some were using a fuel filter.
I purchased one from azone and I'm glad I didn't spend a lot of money because not much oil is passing through that line. If you want more info, pm me and I'll put up a new post with pics.
That's not the case with LS1 motor's.. they ingest alot of oil. Catch can works great at stopping it.
Another vote for a AMW kit.
Old Jun 15, 2005 | 11:44 PM
Dan_the_C5_Man's Avatar
And not all of the oil is coming through the PCV system..
Old Jun 16, 2005 | 02:46 AM
ChrisLe's Avatar
Old Jun 16, 2005 | 08:45 AM
Z'mnypit's Avatar
I read a long time ago the some LS1's have PCV oil consumption problems.
I figured that since mine was a POS '98, I probably have this issue.
I searched on line for some DIY catch can designs and I found some pretty cool DIY catch can projects but after searching far and wide, the simplest one I came across was a small fuel filter in-line with the PCV hose.
Of course, if you're LS1 does indeed have the oil consumption issue, this is not a permanent fix since there is not very much capacity in this design.
http://www.shinken.us/pcv.htm
Yes, my website sucks! It's a work in progress and this went from concept to final in 1 hour.
Is it just me or is your hose connected in the wrong place. You have the hose connected to the throttle body. Its suppose to go right behind & below the throttle body connecting to the intake. Well, at least thats were mines at, & all the others Ive seen. Someone please correct me if Im wrong.
Old Jun 16, 2005 | 09:29 AM
kenkaru's Avatar
Oh man! I put the filter in line with the vent tube that goes to the top of the valve cover! LMAO I feel like a retard! I thought that was the PCV. Maybe that's why I hardly getting any oil in that line!
I'll be deleting my previous posts at this time!!!
Thanks! hahaahahha
Old Jun 16, 2005 | 09:52 AM
Z'mnypit's Avatar
Thanks! hahaahahha
No problem! Yeah once you swap it around & hook it into the intake you see a good bit of oil then. Heres an old pic of my home made catch can. Maybe you can tell.
Old Jul 29, 2006 | 08:06 PM
PewterNHRA2001's Avatar
just did this today, only thing is it seems like the plastic would melt being soo close to the engine, or maybe its just my clogged cat thats making the passenger side soo hot
Old Jul 30, 2006 | 12:08 PM
INMY01TA's Avatar
AMW's nice but rediculously exspensive. Ebay has em like $15-$30.
Old Jul 30, 2006 | 01:44 PM
Ripper415's Avatar
wait, since my car is an 02 SS with the LS6 intake, do I need one of these catch cans or did gm fix that problem with the new LS6?
Old Jul 30, 2006 | 01:52 PM
kenkaru's Avatar
You need NOS. This one... no THIS one... two of em... and Ripper, you need em by TONIGHT!
Old Jul 30, 2006 | 02:39 PM
HeapaShifter's Avatar
I have the same one Z'mnypit has. It's a Husky inline filter for an air compressor. Available at Home Depot. Cost about $12. Works great.
Old Jul 30, 2006 | 02:50 PM
Frosty's Avatar
Old Jul 30, 2006 | 10:53 PM
bene's Avatar
Trunion King
+1 huskee model.
