clutch bleed
took from the sticky above^
"To bleed the system, you will need a 7/16th” socket, thin-walled, in ¼ drive. It would behoove you to use a few swivels and extensions. I also highly recommend taping the socket to the extension/swivel/etc. If for some reason you drop the socket, it will end up at the bottom of the bellhousing and you will have a hell of a time fishing it out".
