why does this dick harrell prototype use a zo6 clutch?
in gm high tech performance september mag, the dick harrell edition prototype uses a zo6 clutch and spec flywheel, . . its mods are: a 427, ported ls6 heads, 244/248 .612/.615 cam, kooks headers, gmmg exhaust and cutout with a strange rear end, with other small supporting mods, . . . its best et is 10.94 at 125 on pump gas witha 60 ft of 1.46, . . . they went all out modding this car but put a mild clutch in?
Is it a LS7 clutch? If so then it's a pretty good clutch., with good grab but you can still slip it. Maybe they still wanted some streetability.
Unless it was an LS6, then I'm lost with you.
