Help Please!
Help Please!
I was working on my car today and i seen the belt had a mark in the center so i check the pulleys and the tensioner pulley for my 6 rib setup is worn away and is now cutting the belt. Where can i get a new pulley? Also wiht the 6 rib kit could i get away with 8-9lbs of boost? Will i have bad slippage? I want to do the 8 rib upgrade but i dont have near enough money to do it. If the stock 6 rib crank pulley is 5.82 and if i get a 3.10" pulley for the procharger will i make 8 psi with long tubes? Any help on this subject would be great. Also where can i get a new belt for it? Anyone have these parts laying around? Let me know asap please
I used to run a reichard racing 3.2" pulley and thats about as small as I would go on the 6 rib. The RR 'ultragrip' pulleys work very well but you have to keep on the tension. I made ~8psi with FLP headers and cats and a stock engine and P1SC.
Bob can hook you up with a new idler pulley, thats a normal thing to happen, he can also get you a regular 3.2 pulley from ATI - may work OK for you if you dont want to spend the 200 on the ultragrip.
Thanks guys, I appreciate it!
The MMS crank pulley is probably the best way to go for the six rib, to add more boost. Here is a link to one that was for sale some time ago.
https://ls1tech.com/forums/showthrea...Charger+pulley
If you place a post in the wanted section, you can probably come up with one. I went from 7 psi to 14 psi of boost with this crank pulley, with a 4.00" pulley on the blower. This will give you much better belt wrap which will reduce belt slippage. Bob
i want to get the sdce 6 rib self tensioner kit and the pin kit. With this kit could i run 8 -10 lbs wiht no slippage? I cant afford the 8 rib so thats out of the question.
SO i can run my 9psi with no slip issues? Can i use my stock balancer and bottom pulley? Im planning to get the pinning kit at same time. Just new to this yet and still figuring what im gonna need. I just had the car dynoed like 3 days ago iwth the pulley like that and the belt is sloppy how much boost do u think is lost? I still dynoed at 411/382.
Dont know what kind of trans you have but with stock exhaust around 450-475 is normal with a M6 and stock exhaust depending on the tune and pulley size of course. Belt has to be like piano string not to slip.
I'm not real familair wit the 6 rib SDCE, I imagine its cheaper then the 8 rib because it uses the stock procharger crank pulley. I dont see getting 9-10psi being a problem at all with the SDCE 6 rib, I got nearly that much with the stock tensioner and the RR 3.2 pulley. Another added benefit of the SDCE is it will really cut down the blower rattle at idle.
i have an m6 car. I have manifolds rite now but i want to get headers very soon. I want to get this pulley situation straightened first. I really like that blower rattle.
It will take a little playing with but you should get close to 500rwhp with headers, good tune and 8-9psi. Always a good idea to stock some LS6 valvesprings on the heads for a little insurance.
I jsut hope the 6 rib sdce setup works cause i caleed them twice and noone called me back at all kinda pissed me off. I want to know what psi its good to without slippage.
Where can u get bigger crank pullies? and blower pullies? Im assuming i use my stock balancer with the 6 rib sdce kit. Hope so anyways. I hope the kit straightens out the slippage problems tho
