SDCE 6 Rib Spring Tesnioner
Old 08-15-2006, 07:27 PM
Whitez406's Avatar
Default SDCE 6 Rib Spring Tesnioner
Anyone out there using the 6 rib kit? I have a p1sc and i dont ever plan to run more then 10psi on on and if i do it wil be many moons from now but does anyone have belt slippage issues with these or does anyone know what maximum boost is with these or any other useful info aobut it. Thanks
Old 08-15-2006, 09:03 PM
Whitez406's Avatar
ttt...very important thanks everyone youve been a big help so far.
Old 08-15-2006, 09:11 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
i im sure on how good the 6rib setup is from them but i know for a fact the 8rib setup works great with no problems. save a little more and get the 8 rib i used them on a few cars.
Old 08-15-2006, 10:17 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Straight to the point: Go with the 8 rib and do not look at anything else.
Old 08-16-2006, 01:12 AM
bmfcamaro's Avatar
do you even need it with 10lbs of boost?
Old 08-16-2006, 05:29 AM
EPP
EPP's Avatar
You could look for a used MMS crank pulley, which is larger than the ATI 6 rib crank pulley. MMS doesn't make them anymore, but you can find them used on here. You can easily make 10 psi without belt slippage with this pulley, and have approx $200.00 in the pulley and belt. Bob
Old 08-16-2006, 08:32 AM
Whitez406's Avatar
u dont need it for 10lbs of boost but i dotn want to tighten the belt and replace the stupid aluminum idler that weres out all the time. I got other things to buy so the 8 rib is out of the question for me. If someone has got a used setup maybe. Can u use the stock balnacer?
Quick Reply: SDCE 6 Rib Spring Tesnioner
