Tough converter (TH400)
Old 08-23-2006, 08:41 PM
TchargedLS1TA's Avatar
Default Tough converter (TH400)
Is it just me or are TH400 converters a pain in the *** to engage onto the tranny? I can only get it to engage the input shaft and thats it..
Old 08-23-2006, 10:38 PM
revtime's Avatar
Mine went in like butter.
Rotate the converter while pushing in and it should engage.
Old 08-24-2006, 11:09 AM
Been doing that and it dont want to engage... Once I get the first shaft engaged, I have no up and down movement. I stating to think this is the wrong converter..
Old 08-24-2006, 01:27 PM
12secSS's Avatar
Some converters are very tight engaging, by wiggling the converter it should help. Mine recently took a bit of effort to get in, but it finally did. Mine was setup pretty tight and when I found the right spot, it slid right in. My recommendation would be to have the trans input shaft face up and try to install the converter that way. I know, it will be dry, but at least if it fits, you know it is properly setup.
Old 08-25-2006, 04:27 AM
silkey's Avatar
just fiddle with it.sometimes i have more luck when i just stop trying and start doing stupid stuff like turning the converter at odd angles or spinning it not really being serious with it,and it will just drop in.go figure.
