short stick keeps coming loose??
recently installed the pro 5.0 and lou's short stick, no complaints except that every now and then the bolts holding the stick in place keep coming loose and the stick gets loose.
anyone else have this problem?
Originally Posted by slowscott
I had this problem once. Then I reinstalled it with loctite, lock washers and then wrapped it with duct tape. Hope that helps.
scott
scott
Blue Loctite fixed it for me. I made the mistake of only putting it on the top bolt the first time, and had to go back and do both bolts about a month later. Been quite a while since then, and it's still as solid as if it had been welded. I yank the **** out of it, too.
