Do I need a new master cylinder?
Old 09-03-2006, 05:07 PM
dvzz28's Avatar
Default Do I need a new master cylinder?
In my 98 z28 the clutch went out so, as was second gear. The hydralics worked fine til clutch went bad. I am going to put a new slave in it, but is the master cylinder neccessary. T56 rebuids did the trans and I'm using a spec clutch. Also have a new SFI flywheel. Thanks guys
Old 09-03-2006, 09:29 PM
LS1TECH Sponsor
badpewter-z's Avatar
it wouldnt hurt to do it as it has been updated since 98 for better perfomance and less issues. at the least i would drill the restrictor out
Old 09-04-2006, 03:39 PM
dvzz28's Avatar
that was an option i was considering
Old 09-04-2006, 04:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Definitely drill mod that bad boy.
