Drag Racing Tech
What spring to use after mini tub/ & Wolfe spring adjuster?
Old 09-12-2006, 04:28 PM
Black Sunshine/ 00SS's Avatar
Default What spring to use after mini tub/ & Wolfe spring adjuster?
When the car is mini tubbed, I plan to use a smaller diameter spring, along with the Wolfe adjusters, to gain all the clearance I can get.
What rate spring to use on a street driven car? Mid 9 sec car. I want something that is the same, or close to the stock spring.
Old 09-12-2006, 07:30 PM
LS1Tech Sponsor
MADMAN's Avatar
usually for a street driven car I use a 175lbs X 12" spring.
__________________
www.madmanandcoracing.com
225-343-9029
Old 09-12-2006, 08:23 PM
Thanks. Who makes that spring, QA1? Can I get that through Thunder?
Does that spring have a smaller diameter than the stock one?
Old 09-12-2006, 08:36 PM
skipperbisket's Avatar
madman, for a strip car that sees very seldom street time would you reccomend that same 175x12 spring or something different?
Old 09-13-2006, 10:00 AM
I ruin the end of films...
mongse's Avatar
I've got a 150x12 under mine. I ordered mine through Spohn because I knew the part number (and I'm a dealer for them ).
Old 09-13-2006, 11:22 AM
LS1Tech Sponsor
MADMAN's Avatar
I will be more than happy to sell you the springs. I have either AFCO or QA1 in stock in the 2.5" sizes.
On a drag car I usually use the 150lb. x 10 "
__________________
225-343-9029
