Injector questions
Injector questions
With my current setup i'm making 400rwhp with about 4-5psi and i'm going to run 12-15psi here shortly with my P1SC. Do you guys think my 42lb injectors will be able to handle this, and will i be safe to run on pump gas (91)?
Each injector supports roughly 77hp. So, depending on where you want to be, do the math, then divide by 20% to get your rough wheel HP level.
Hint: they will support ~493rwhp.
I don't really have a power goal, but I have already recieved my new pullies from exotic performance plus and I told them I wanted to be between 12-15psi. and this winter i'm going to upgrade to a D1SC and that will be it for me as far as performance goes. What kind of gains do you guys think I should expect to get from this pully swap? Oh and btw I have an auto with a 3000 stall.
