boiling clutch fluid?
Boiling creates air in the line. That's why old oil is not so good. It gets contaminated with water and boils at a lower temperature.
air=bad
Do you have headers? Does the line go close to it? Did you remove the heat shield?
air=bad
no i still have the stock manifolds i heard it happens with those too....it was weird i replaced my hydraulics and it was fine for over 2 months...then i was driving it one night and it ground 2nd gear and was harder to shift so i opened the resivoir and it was completly empty? i have no idea what happened there arent any leaks as far as i know there isnt any fluid dripping
