sporadic noise when going from a stop...
I had a ram clutch installed about 2 weeks ago. I noticed a sporadic noise when i would slowly let the clutch up from a stop. Today it did it like 4-5 times, but usually its once a day if that. It sounds like a bad belt slipping noise (its def not a belt though), or something slipping, its pretty loud and i can feel it through my pedal. It sucks that its sporadic so it will be hard to take it back to the shop that did the work and show them. When i had the clutch put in i had them put a new friction plate on the aluminum spec flywheel and a new slave cylinder. Anyone have any idea what the noise can be?
Its right as i am letting up the clutch to go from a stop and it makes the noise for a split second, i can actually feel it but it doesnt seem to effect the car.
It hasnt done it at any other time besides takeoff.
from searching it sounds like a bad throwout bearing, can anyone else give me some input? I provided the shop with a new throwout bearing, could the shop not install it correctly and cause it to start going bad after only about 300 miles? Or does it sound like the shop never installed my new throwout bearing and just reused mine that had 60k miles on it?
Any help is appreciated, thanks
Originally Posted by KDR-Z06
I noticed a sporadic noise when i would slowly let the clutch up from a stop. It sounds like a bad belt slipping noise.
Originally Posted by Roadhouse
It shouldn't.
I searched on z06vette.com and there was someone with very similar symptoms and people were guessing it might be a throwout bearing, would a throwout bearing do this?
I had a spec that did the same thing, annoing as hell and it makes you think everyone is looking at you and saying that car is a pile. I havent heard of it with a ram but Im sure that some may do it. I know with the textralia they say that the clutch is not fully seated yet and to basically beat on it but I am not sure that will work with yours.
This may be somthing you will have to live with.
i emailed ram and they say a squealing noise is normal when the clutch is cold but i talked to 2 different people that have the same clutch and they dont have the issue, can it be due to them having a different flywheel then me? I have a fidanza and they have billet steel ram flywheels. The noise does go away after it warms up but its so loud that i am not convinced this is the squealing noise ram is talking about.
