throw away block?
throw away block?
someone at a chrevrolet dealership said this.... if one has spun a bearing in a LS1 motor, being all aluminum, there is no reason to try to salvage the block. suggested throwing the block away and getting new. where as i wanted to get a new rotating assembly (forged) and go with it from there. what do you think. money being an issue..
Sounds like a spun bearing. You can rebuild it if you had the know how. Your buddy just thinks that aluminum blocks are weak and cant hold up. His is mistakening a spun bearing for a rod through the side. Rebuild it if money is an issue, I have about 700 into mine but that was with a new cam and bearings.
If the damage is bad enough, an aluminum block can even be welded to bring the mains back to size, and then align bored. But I'd say that's an extreme case.
If you have the time for the machine work and such, I can't think of any reason why your block couldn't be salvaged.
Race your car!
It can be saved if it's a spun bearing, hearing something like that come from a GM dealer, for some reason doesn't surprise me at all.
Get it apart and see what's going on, there's bearings available that can take up the extra slack I am sure of it, and even if there's not, like mentioned above welding the block and reboring it is a viable option, and not that expensive. Alum is repairable and not that expensive to do. Only thing that really will scrap a block is a broken sleeve or a rod /piston breaking and getting ejected out the side.
FWIW< I ahve seen alum heads that had a nitrous hot spot actually melt a hole thru them, and they were able to be saved.. some of the shops out there can really work some wonders with alum if they know what they are doing... get it apart and assess the situation.
Race your car!
Originally Posted by Adnectere
JL ws-6, I love your signature quote.
"racing a FWD car is like running in the special olympics, even if you win, you are still retarded"
"the only thing worse on a dragstrip then a ricer, is a snowmoblie"
"neon, great for the sign at joe's diner, not so great for driving"
Those usually really get some people heated though... so I refrain from it now, I just found a decent quotable line on here, and use that. It gets the point across.
Another on topic question for the thread starter... have you gotten the motor apart yet? Is there a spun bearing? If so,how bad does it look?
ok found a spun rod bearing on the number 7 cylinder. ive heard our blocks cant be bored, only honed. is that true? and our stock blocks...are they already sleeved? what is the sleeve made out of, if it is... looking to clean up the bore, put a 4 inch crank in there, with new rods and pistons...all forged, for future N2O use
