Pics/Built Specs Of LT1s Stroker with Superchargers
Old 09-28-2006, 08:52 PM
frbrd7996's Avatar
Default Pics/Built Specs Of LT1s Stroker with Superchargers
If anybody has any pics of there motor and the specs,I would love to compare.Also how much power due you put down?
Old 09-28-2006, 09:59 PM
faSSter's Avatar
I have tried to keep up with some stroker/blower LT1 buildups and outputs for about a year now. I am trying to find a good combination for my Impala. So far, all I have is heads, procharger kit, crank, rods, and block. Now I'm trying to pick out cam and pistons. Anyway, here are some of the combos I have written down. All of these had dyno sheets to prove their power claim. They were all gathered over other forums.
5.7" oliver forged rods
JE -31cc forged pistons
comp type R lifters
LT4 timing kit
comp pushrods
GM LT1 alum heads w/ 2/0/1.6 valves
comp pro-mag rockers, 1.6 ratio
comp TS-224XL cam 224/236 .536/.555 114LSA
walbro 340
delphi 52 lb. injectors
stock GM f-body MAF
ATI D1SC 15 psi twin core intercooler
58mm TB
long tube headers
3" exhaust w/ x pipe, spintech prostreet mufflers
The above combo was installed in an Impala. It made 556 RWHP and 669 RWTQ. With a 100 shot of nitrous, it made 653 RWHP and 729 RWTQ
Along with a 2800 stall and 3.73s, this engine was capable of pulling a full weight impala (~4150 lbs.) down the 1/4 mile in 11.31@118. Not bad for grandma's grocery getter 4 door.
Old 09-28-2006, 10:01 PM
faSSter's Avatar
Another combo:
The only specs I have on this one are as follows:
383"
LT4 heads ported by Lloyd Elliot
224/236 cam
8.5 psi
519 RWHP 491RWTQ
Old 09-28-2006, 10:03 PM
faSSter's Avatar
Another Impala:
8.5:1 383 inch
10psi
comp 227/239
lunati timing chain
stage 2 LT1 iron heads with 2.02/1.6 valves
3 angle valve job
1.6 comp roller rockers
long tubes
3" exhaust with flowmaster 40s
622 RWHP
Old 09-28-2006, 10:08 PM
faSSter's Avatar
Not a stroker:
355 inch LT1
stock crank, stock rods, forged pistons
vortech s-trim at 14 psi
stock unported iron LT1 heads
LT4 hot cam kit
NX100 shot
50lb injectors
632.7RWHP 690RWTQ
Pushed a full-weight impala down the 1/4 mile in 11.13@125 on the nitrous.
I would strongly recommend that no one ever tries this setup. The stock rods and crank won't last long. Last I heard it was still working for him, but I wouldn't take the chance.
That's all I have.
Paul
Old 09-28-2006, 10:23 PM
engineermike's Avatar
My old combo was:
383 cid, 8.3/1
AFR 210 Race Readies, out the box.
224/236-114 high lift.
Aftercooled Vortech T-trim at 13 psi.
TH350 and a 4000 stall converter.
Dyno'd 550 rwhp and ran 10.40 at 133 mph at 3750 lb.
Mike
Quick Reply: Pics/Built Specs Of LT1s Stroker with Superchargers
